传奇私服服务器怎么增加npc,在自己的传奇服务器中如何添加NPC
该楼层疑似违规已被系统折叠 隐藏此楼查看此楼
(转)在自己的传奇服务器中如何添加NPC
[@main]
check [001] 1
goto @away
checklevel 255
#SAY
Welcome .[BACKSLASH]
I will give you items to suit your class :)[BACKSLASH] [BACKSLASH]
[BACKSLASH]
[BACKSLASH]
#ELSESAY
You do not appear to be the lord,[BACKSLASH]
or his Companion![BACKSLASH]
Go away![BACKSLASH] [BACKSLASH]
[@away]
, why do you return so soon?[BACKSLASH]
I have given you your items, what you did with them[BACKSLASH]
is none of my concern, please leave, i have a bad head![BACKSLASH] [BACKSLASH]
:-( [BACKSLASH]
[@next]
You will have to tell me your gender, i have poor eyesight[BACKSLASH]
and poor hearing... [BACKSLASH] [BACKSLASH]
[BACKSLASH]
[BACKSLASH]
[@male]
checkjob Warrior
give DragonSlayer 1
give PowerRing 2
give GreenBead 1
give SteelArmour(m)
give BlackIronHelm 1
give BlackIronGlove 2
give ParalysisRing 1
SET [001] 1
#SAY
A big strong warrior such as you [BACKSLASH]
should have these items![BACKSLASH]
#ELSEACT
goto @mwiz
[@mwiz]
checkjob wizard
give DragonStaff 1
give DragonRobe(M) 1
give DragonBracelet 2
give DemonicBells 1
give SpiritRing 2
give VioletRing 2
give ProtectionRing 1
give RecoveryRing 1
SET [001] 1
#SAY
You are a proud wizard ,
Take these items![BACKSLASH] [BACKSLASH]
#ELSEACT
goto @mtao
[@mtao]
checkjob taoist
give SoulSabre 1
give TitanArmour(M) 1
give TitanRing 2
give SoulBracelet 2
give SoulNecklace 1
give Amulet 5
SET [001] 1
#SAY
Aha! a well trained taoist deserves these items![BACKSLASH] [BACKSLASH]
[@female]
checkjob Warrior
give DragonSlayer 1
give PowerRing 2
give GreenBead 1
give SteelArmour(f)
SET [001] 1
#SAY
#ELSEACT
goto @fwiz
[@fwiz]
checkjob wizard
give DragonStaff 1
give DragonRobe(f) 1
give DemonicBells 1
give SpiritRing 2
give VioletRing 2
give RecoveryRing 1
SET [001] 1
#SAY
#ELSEACT
goto @ftao
[@ftao]
checkjob taoist
give SoulSabre 1
give TitanArmour(F) 1
give TitanRing 2
give SoulBracelet 2
give SoulNecklace 1
give Amulet 5
SET [001] 1
#SAY
Sorry, but for some reason this forum erases backslashes,
copy this into note pad, then press ctrl+h (REPLACE)
type in the search field "[BACKSLASH]"
type in the replace with field (bah silly forum) "backslash", but not the word :-P
then hit replace all.
that should be it done, u should see all [BACKSLASH] replaced b an actual backslash.
上一篇: 传奇996_1——添加npc补丁
下一篇: 传奇gee引擎,智能假人,假人脚本,geeM2假人
