[按键精灵]安卓/ios辅助工具脚本开发8个有用的代码段
38 阅读
使用按键精灵安卓/ios辅助工具脚本开发中一些写常用的功能性的代码段分享:
(1) 不重复的写入文本
 Dim path = "/sdcard/pictures/账号.txt" Function FileWrite(path,str) Dim arr = file.readlines(path) If Len(arr) = 0 Then File.Write(path, str&"\r\n") Else For i = 1 To Len(arr) If arr[i] = str Then Exit For End If If i = Len(arr) Then File.Append(path, str&"\r\n") End If Next End If End Function
(2)文本读一行删一行
 Dim path = "/sdcard/pictures/账号.txt" TracePrint fileReadLine(path) Function fileReadLine(path) Dim str = file.readline(path,1) If Len(str) > 0 Then file.DeleteLine path, 1 fileReadLine = str Else TracePrint "文本内容已空" End If End Function
(3)获取小精灵包名
 TracePrint getPackage() Function getPackage() Dim path = GetTempDir() Dim arr = split(path, "/") getPackage = arr[ubound(arr)] End Function
(4)对数组进行排序
 Dim arr = {13,7,4,18,17,26,7,19,10} Dim ret = sorted(arr) TracePrint encode.TableToJson(ret) Function sorted(arr) Dim num For UBOUND(arr) For i = 1 To UBOUND(arr) If arr[i] > arr[i + 1] Then num = arr[i] arr[i] = arr[i + 1] arr[i+1] = num End If Next Next sorted = arr End Function
(5)查找数组最大值和最小值
 Dim Matharr = {13,7,4,18,17,26,7,19,10} Traceprint "数组中最大值:",MathMax (arr) TracePrint Encode.TableToJson(arr) //修改了数组内容 Traceprint "数组中最小值:",MathMin (arr) Function MathMax(arr) For i = 1 To UBOUND(arr) If arr[i] > arr[i + 1] Then arr[i+1] = arr[i] End If Next MathMax = arr[len(arr)] End Function Function MathMin(arr) For i = 1 To UBOUND(arr) If arr[i] < arr[i + 1] Then arr[i+1] = arr[i] End If Next MathMin = arr[len(arr)] End Function
(6)拆分打码平台的坐标返回值
 Import "shanhai.lua" Dim ret = "435,147|684,352|224,66|451,116" splitCoordinate(ret) Function splitCoordinate(ret) Dim arr = shanhai.RegexFindEx(ret,"(%d+),(%d+)") For i = 1 To Len(arr) TracePrint arr[i][1],arr[i][2] Next End Function
(7)字符串拆分成数组
 Dim str = "12345456" Dim arr = strAsArr(str) TracePrint encode.TableToJson(arr) Function strAsArr(str) Dim arr = {null} For i = 1 To Len(str) arr[i] = mid(str,i,1) Next strAsArr = arr End Function
(8)定时脚本
 import "shanhai.lua" Dim 小时 = 19 Dim 分钟 = 44 If fixedTime(小时, 分钟) Then TracePrint "到时间了" Else TracePrint "没有到时间" End If Function fixedTime(h, m) Dim t = Now() Dim arr_time = shanhai.RegexFind(t,"(%d+):") TracePrint arr_time[1],arr_time[2] If cint(arr_time[1]) = cint(h) and cint(arr_time[2]) = cint(m) Then fixedTime = true End If End Function
上一篇: 【免费下载】 Creator-传奇框架带资源
下一篇: 传奇996_73——附加属性setitemaddvalue
