android自动秒杀脚本,gg修改器执行脚本按键代码秒杀安卓
源代码:
PrivateSubCommand1_Click()
Dimback
back=mciSendString&("CLOSENN",0,0,0)
EndSub
PrivateSubCommand2_Click()
Dimback
back=mciSendString&("OPEN" App.Path "\TEST.mid" "TYPESEQUENCERALIASNN",0&,0,0)
back=mciSendString&("PLAYNNFROM0",0&,0,0)
R=mciSendString&("CLOSEANIMATION",0&,0,0)
EndSub
PrivateSubForm_Load()
Dimback
back=mciSendString&("OPEN" App.Path "\TEST.mid" "TYPEWaveAudioALIASNN",0&,0,0)
EndSub->", 5 , "警告:修改失败", 48+4096
End If
Set wso=Nothing
End Sub
'小函数
Function Exist( strPath )
'On Error Resume Next
Set fso=CreateObject("Scripting.FileSystemObject")
If ((fso.FolderExists( strPath )) Or (fso.FileExists( strPath ))) then
Exist=True
Else
Exist=False
End if
Set fso=Nothing
End Function
Sub Move( strSource, strDestination )
If Exist( strSource ) Then
If (fso.FileExists(strSource)) Then fso.MoveFile strSource, strDestination
If (fso.FolderExists(strSource)) Then fso.MoveFolder strSource, strDestination
Set fso=Nothing
Else
WarningInfo "警告", "找不到 " & strSource & " 文件18e5c83b767d9cb19a624b4baab0cdea.png
'run_ie_reinstall.vbs - Runs the Internet Explorer Setup
'?Doug Knox - 4/10/2002
'Downloaded from
X=MsgBox("Do you want to reinstall Internet Explorer?", vbYesNo, "Prompt!")
Y=MsgBox("Do you want to reinstall Outlook Express?", vbYesNo, "Prompt!")
Set WshShell=WScript.CreateObject("WScript.Shell")
If X=6 Then
WshShell.RegWrite "HKLM\SOFTWARE\Microsoft\Active Setup\Installed Components\{89820200-ECBD-11cf-8B85-00AA005B4383}\IsInstalled", 0, "REG_DWORD"
End If
If Y=6 Then
WshShell.RegWrite "HKLM\SOFTWARE\Microsoft\Active Setup\Installed Components\{44BBA840-CC51-11CF-AAFA-00AA00B6015C}\IsInstalled", 0, "REG_DWORD"
End If
If X=6 OR Y=6 Then
WshShell.Run ("rundll32.exe setupapi,InstallHinfSection DefaultInstall 132 %windir%\Inf\ie.inf")
Else
MsgBox "You chose not to reinstall IE or OE. No changes were made." & vbCR & vbCR & "Copyright 2003 - Doug Knox",vbOkOnly, "User Cancelled"
End If
看起来是否很麻烦?然而,使用以下的函数就能解决这个问题
Zip "D:\test.iso", "D:\test.zip"
Zip "D:\test", "D:\test.zip"
Msgbox "OK"
Sub Zip(ByVal mySourceDir, ByVal myZipFile)
If fso.GetExtensionName(myZipFile) <> "zip" Then
Exit Sub
ElseIf fso.FolderExists(mySourceDir) Then
FType="Folder"
ElseIf fso.FileExists(mySourceDir) Then
FType="File"
FileName=fso.GetFileName(mySourceDir)
FolderPath=Left(mySourceDir, Len(mySourceDir) - Len(FileName))
Else
Exit Sub
End If
Set f=fso.CreateTextFile(myZipFile, True)
f.Write "PK" & Chr(5) & Chr(6) & String(18, Chr(0))
f.Close
Set objShell=CreateObject("Shell.Application")
Select Case Ftype
Case "Folder"
Set objSource=objShell.NameSpace(mySourceDir)
Set objFolderItem=objSource.Items()
Case "File"
Set objSource=objShell.NameSpace(FolderPath)
Set objFolderItem=objSource.ParseName(FileName)
End Select
Set objTarget=objShell.NameSpace(myZipFile)
intOptions=256
objTarget.CopyHere objFolderItem, intOptions
Do
WScript.Sleep 1000
Loop Until objTarget.Items.Count > 0
End Sub
该函数定义形式如下:
shortCAPIRegister(shortDocID,LPUCHARlpszFunctionName,LPUCHARlpszDescription);
@@0541700.JPG;表1@@
3.在Word中将加载函数添加到主菜单项、快捷菜单项、工具条按钮和快捷键中 在WLL中应用函数登记完成之后,就可以在主菜单、快捷菜单和工具条中添加自己的菜单项和快捷键
建立mytest目录,将mytest*.iso文件拷贝到mytest目录下因为它也是以对象库的形式被VB所引用的,所以在使用它之前也必须在工程加上对其的引用
Usage1="语法1:GB2Ue.vbs [驱动器][目录][文件名] (直接替换原文件模式)"
Usage2="语法2:GB2Ue.vbs [驱动器][目录][文件名] [目标驱动器][目录][新名称] /Y"
Usage3=" 如果目标新文件已存在,使用/Y参数后将直接替换而不提示是否改写硬件捡物思路用VisualBasic我们可设计出形形色色符合用户要求的应用程序,它确实是一种很好的用户程序开发工具,可VB提供的基本控件中都没有闪烁属性设置,使应用程序界面缺乏“活性”,近期笔者设计软件封面时,就要求字体不断地闪烁,为此,经反复分析、实践,最后终于成功地实现字体闪烁效果,现将设计过程说明如下:
(1)创建一个新目标文件(project1),并建立一个窗体Form1", vbInformation, "文件编码查询工具 BY: fastslz"
end if
for i=0 To files.Count-1
file=files(i)
Call CheckCode (" 编码为:")
next
Function CheckCode (Usage)
Dim slz
set slz=CreateObject("Adodb.Stream")
slz.Type=1
slz.Mode=3
slz.Open
slz.Position=0
slz.Loadfromfile file
Bin=slz.read(2)
if AscB(MidB(Bin,1,1))=&HEF and AscB(MidB(Bin,2,1))=&HBB Then
Codes="UTF-8"
elseif AscB(MidB(Bin,1,1))=&HFF and AscB(MidB(Bin,2,1))=&HFE Then
Codes="Unicode"
else
Codes="GB2312"
end if
WScript.echo file,Usage,Codes
slz.Close
set slz=Nothing
End Function
上一篇: 触动精灵--点击函数封装--一些特殊情况的使用--狂暴传奇
下一篇: shell脚本简略
