python 传奇辅助_php
66 阅读
5IgxvbAAAAAElFTkSuQmCC
PHP Version 5.6.13
SystemWindows NT 10_243_140_222 6.3 build 9600 (Windows Server 2012 R2 Standard Edition) AMD64
Build DateSep 3 2015 15:08:06
CompilerMSVC11 (Visual C++ 2012)
Architecturex64
Configure Commandcscript /nologo configure.js "--enable-snapshot-build" "--enable-debug-pack" "--disable-zts" "--disable-isapi" "--disable-nsapi" "--without-mssql" "--without-pdo-mssql" "--without-pi3web" "--with-pdo-oci=c:\php-sdk\oracle\x64\instantclient_12_1\sdk,shared" "--with-oci8-12c=c:\php-sdk\oracle\x64\instantclient_12_1\sdk,shared" "--with-enchant=shared" "--enable-object-out-dir=../obj/" "--enable-com-dotnet=shared" "--with-mcrypt=static" "--without-analyzer" "--with-pgo"
Server APICGI/FastCGI
Virtual Directory Supportdisabled
Configuration File (php.ini) PathC:\Windows
Loaded Configuration FileC:\Program Files\php\php.ini
Scan this dir for additional .ini files(none)
Additional .ini files parsed(none)
PHP API20131106
PHP Extension20131226
Zend Extension220131226
Zend Extension BuildAPI220131226,NTS,VC11
PHP Extension BuildAPI20131226,NTS,VC11
Debug Buildno
Thread Safetydisabled
Zend Signal Handlingdisabled
Zend Memory Managerenabled
Zend Multibyte Supportprovided by mbstring
IPv6 Supportenabled
DTrace Supportdisabled
Registered PHP Streamsphp, file, glob, data, http, ftp, zip, compress.zlib, phar
Registered Stream Socket Transportstcp, udp
Registered Stream Filtersconvert.iconv.*, mcrypt.*, mdecrypt.*, string.rot13, string.toupper, string.tolower, string.strip_tags, convert.*, consumed, dechunk, zlib.*
toAAAAASUVORK5CYII=
This program makes use of the Zend Scripting Language Engine:
Zend Engine v2.6.0, Copyright (c) 1998-2015 Zend Technologies
with Zend OPcache v7.0.6-dev, Copyright (c) 1999-2015, by Zend Technologies
Configuration
BCMath supportenabled
DirectiveLocal ValueMaster Value
bcmath.scale00
Calendar supportenabled
cgi.check_shebang_line11
cgi.discard_path00
cgi.fix_pathinfo11
cgi.force_redirect00
cgi.nph00
cgi.redirect_status_envno valueno value
cgi.rfc2616_headers11
fastcgi.impersonate11
fastcgi.logging11
PHP Version5.6.13
allow_url_fopenOnOn
allow_url_includeOffOff
always_populate_raw_post_data00
arg_separator.input&&
arg_separator.output&&
asp_tagsOffOff
auto_append_fileno valueno value
auto_globals_jitOnOn
auto_prepend_fileno valueno value
browscapno valueno value
default_charsetUTF-8UTF-8
default_mimetypetext/htmltext/html
disable_classesno valueno value
disable_functionsno valueno value
display_errorsOffOff
display_startup_errorsOffOff
doc_rootno valueno value
docref_extno valueno value
docref_rootno valueno value
enable_dlOffOff
enable_post_data_readingOnOn
error_append_stringno valueno value
error_logno valueno value
error_prepend_stringno valueno value
error_reporting2252722527
exit_on_timeoutOffOff
expose_phpOnOn
extension_dirC:\Program Files\php\extC:\Program Files\php\ext
file_uploadsOnOn
highlight.comment#FF8000#FF8000
highlight.default#0000BB#0000BB
highlight.html#000000#000000
highlight.keyword#007700#007700
highlight.string#DD0000#DD0000
html_errorsOnOn
ignore_repeated_errorsOffOff
ignore_repeated_sourceOffOff
ignore_user_abortOffOff
implicit_flushOffOff
include_path.;C:\php\pear.;C:\php\pear
input_encodingno valueno value
internal_encodingno valueno value
log_errorsOnOn
log_errors_max_len10241024
mail.add_x_headerOnOn
mail.force_extra_parametersno valueno value
mail.logno valueno value
max_execution_time3030
max_file_uploads2020
max_input_nesting_level6464
max_input_time6060
max_input_vars10001000
memory_limit128M128M
open_basedirno valueno value
output_buffering40964096
output_encodingno valueno value
output_handlerno valueno value
post_max_size8M8M
precision1414
realpath_cache_size16K16K
realpath_cache_ttl120120
register_argc_argvOffOff
report_memleaksOnOn
report_zend_debugOnOn
request_orderGPGP
sendmail_fromno valueno value
sendmail_pathno valueno value
serialize_precision1717
short_open_tagOnOn
SMTPlocalhostlocalhost
smtp_port2525
sql.safe_modeOffOff
sys_temp_dirno valueno value
track_errorsOffOff
unserialize_callback_funcno valueno value
upload_max_filesize2M2M
upload_tmp_dirno valueno value
user_dirno valueno value
user_ini.cache_ttl300300
user_ini.filename.user.ini.user.ini
variables_orderGPCSGPCS
windows.show_crt_warningOffOff
xmlrpc_error_number00
xmlrpc_errorsOffOff
zend.detect_unicodeOnOn
zend.enable_gcOnOn
zend.multibyteOffOff
zend.script_encodingno valueno value
ctype functionsenabled
cURL supportenabled
cURL Information7.42.1
Age3
Features
AsynchDNSYes
CharConvNo
DebugNo
GSS-NegotiateNo
IDNYes
IPv6Yes
krb4No
LargefileYes
libzYes
NTLMYes
NTLMWBNo
SPNEGOYes
SSLYes
SSPIYes
TLS-SRPNo
Protocolsdict, file, ftp, ftps, gopher, http, https, imap, imaps, ldap, pop3, pop3s, rtsp, scp, sftp, smtp, smtps, telnet, tftp
Hostx86_64-pc-win32
SSL VersionOpenSSL/1.0.1p
ZLib Version1.2.7.3
libSSH Versionlibssh2/1.5.0
date/time supportenabled
"Olson" Timezone Database Version2015.6
Timezone Databaseinternal
Default timezonePRC
date.default_latitude31.766731.7667
date.default_longitude35.233335.2333
date.sunrise_zenith90.58333390.583333
date.sunset_zenith90.58333390.583333
date.timezonePRCPRC
DOM/XMLenabled
DOM/XML API Version20031129
libxml Version2.9.2
HTML Supportenabled
XPath Supportenabled
XPointer Supportenabled
Schema Supportenabled
RelaxNG Supportenabled
Regex LibraryBundled library enabled
EXIF Supportenabled
EXIF Version1.4 $Id: a0425de51ec3270d01522bf62d41bfe78893f78d $
Supported EXIF Version0220
Supported filetypesJPEG,TIFF
exif.decode_jis_intelJISJIS
exif.decode_jis_motorolaJISJIS
exif.decode_unicode_intelUCS-2LEUCS-2LE
exif.decode_unicode_motorolaUCS-2BEUCS-2BE
exif.encode_jisno valueno value
exif.encode_unicodeISO-8859-15ISO-8859-15
Input Validation and Filteringenabled
Revision$Id: 86120bba568c551914a35636ec408f1e7e66af32 $
filter.defaultunsafe_rawunsafe_raw
filter.default_flagsno valueno value
FTP supportenabled
GD Supportenabled
GD Versionbundled (2.1.0 compatible)
FreeType Supportenabled
FreeType Linkagewith freetype
FreeType Version2.5.5
GIF Read Supportenabled
GIF Create Supportenabled
JPEG Supportenabled
libJPEG Version9 compatible
PNG Supportenabled
libPNG Version1.5.18
WBMP Supportenabled
XPM Supportenabled
libXpm Version30411
XBM Supportenabled
WebP Supportenabled
gd.jpeg_ignore_warning00
hash supportenabled
Hashing Enginesmd2 md4 md5 sha1 sha224 sha256 sha384 sha512 ripemd128 ripemd160 ripemd256 ripemd320 whirlpool tiger128,3 tiger160,3 tiger192,3 tiger128,4 tiger160,4 tiger192,4 snefru snefru256 gost gost-crypto adler32 crc32 crc32b fnv132 fnv1a32 fnv164 fnv1a64 joaat haval128,3 haval160,3 haval192,3 haval224,3 haval256,3 haval128,4 haval160,4 haval192,4 haval224,4 haval256,4 haval128,5 haval160,5 haval192,5 haval224,5 haval256,5
iconv supportenabled
iconv implementation"libiconv"
iconv library version1.14
iconv.input_encodingno valueno value
iconv.internal_encodingno valueno value
iconv.output_encodingno valueno value
json supportenabled
json version1.2.1
libXML supportactive
libXML Compiled Version2.9.2
libXML Loaded Version20902
libXML streamsenabled
Multibyte Supportenabled
Multibyte string enginelibmbfl
HTTP input encoding translationdisabled
libmbfl version1.3.2
mbstring extension makes use of "streamable kanji code filter and converter", which is distributed under the GNU Lesser General Public License version 2.1.
Multibyte (japanese) regex supportenabled
Multibyte regex (oniguruma) version5.9.5
mbstring.detect_orderno valueno value
mbstring.encoding_translationOffOff
mbstring.func_overload00
mbstring.http_inputno valueno value
mbstring.http_outputno valueno value
mbstring.http_output_conv_mimetypes^(text/|application/xhtml\+xml)^(text/|application/xhtml\+xml)
mbstring.internal_encodingno valueno value
mbstring.languageneutralneutral
mbstring.strict_detectionOffOff
mbstring.substitute_characterno valueno value
mcrypt supportenabled
mcrypt_filter supportenabled
Version2.5.8
Api No20021217
Supported cipherscast-128 gost rijndael-128 twofish cast-256 loki97 rijndael-192 saferplus wake blowfish-compat des rijndael-256 serpent xtea blowfish enigma rc2 tripledes arcfour
Supported modescbc cfb ctr ecb ncfb nofb ofb stream
mcrypt.algorithms_dirno valueno value
mcrypt.modes_dirno valueno value
MHASH supportEnabled
MHASH API VersionEmulated Support
MySQL Supportenabled
Active Persistent Links0
Active Links0
Client API versionmysqlnd 5.0.11-dev - 20120503 - $Id: 3c688b6bbc30d36af3ac34fdd4b7b5b787fe5555 $
mysql.allow_local_infileOnOn
mysql.allow_persistentOnOn
mysql.connect_timeout6060
mysql.default_hostno valueno value
mysql.default_passwordno valueno value
mysql.default_portno valueno value
mysql.default_socketno valueno value
mysql.default_userno valueno value
mysql.max_linksUnlimitedUnlimited
mysql.max_persistentUnlimitedUnlimited
mysql.trace_modeOffOff
MysqlI Supportenabled
Client API library versionmysqlnd 5.0.11-dev - 20120503 - $Id: 3c688b6bbc30d36af3ac34fdd4b7b5b787fe5555 $
Inactive Persistent Links0
Active Links0
mysqli.allow_local_infileOnOn
mysqli.allow_persistentOnOn
mysqli.default_hostno valueno value
mysqli.default_port33063306
mysqli.default_pwno valueno value
mysqli.default_socketno valueno value
mysqli.default_userno valueno value
mysqli.max_linksUnlimitedUnlimited
mysqli.max_persistentUnlimitedUnlimited
mysqli.reconnectOffOff
mysqli.rollback_on_cached_plinkOffOff
mysqlndenabled
Versionmysqlnd 5.0.11-dev - 20120503 - $Id: 3c688b6bbc30d36af3ac34fdd4b7b5b787fe5555 $
Compressionsupported
core SSLsupported
extended SSLnot supported
Command buffer size4096
Read buffer size32768
Read timeout31536000
Collecting statisticsYes
Collecting memory statisticsNo
Tracingn/a
Loaded pluginsmysqlnd,debug_trace,auth_plugin_mysql_native_password,auth_plugin_mysql_clear_password
API Extensionsmysql,mysqli,pdo_mysql
mysqlnd statistics
bytes_sent0
bytes_received0
packets_sent0
packets_received0
protocol_overhead_in0
protocol_overhead_out0
bytes_received_ok_packet0
bytes_received_eof_packet0
bytes_received_rset_header_packet0
bytes_received_rset_field_meta_packet0
bytes_received_rset_row_packet0
bytes_received_prepare_response_packet0
bytes_received_change_user_packet0
packets_sent_command0
packets_received_ok0
packets_received_eof0
packets_received_rset_header0
packets_received_rset_field_meta0
packets_received_rset_row0
packets_received_prepare_response0
packets_received_change_user0
result_set_queries0
non_result_set_queries0
no_index_used0
bad_index_used0
slow_queries0
buffered_sets0
unbuffered_sets0
ps_buffered_sets0
ps_unbuffered_sets0
flushed_normal_sets0
flushed_ps_sets0
ps_prepared_never_executed0
ps_prepared_once_executed0
rows_fetched_from_server_normal0
rows_fetched_from_server_ps0
rows_buffered_from_client_normal0
rows_buffered_from_client_ps0
rows_fetched_from_client_normal_buffered0
rows_fetched_from_client_normal_unbuffered0
rows_fetched_from_client_ps_buffered0
rows_fetched_from_client_ps_unbuffered0
rows_fetched_from_client_ps_cursor0
rows_affected_normal0
rows_affected_ps0
rows_skipped_normal0
rows_skipped_ps0
copy_on_write_saved0
copy_on_write_performed0
command_buffer_too_small0
connect_success0
connect_failure0
connection_reused0
reconnect0
pconnect_success0
active_connections0
active_persistent_connections0
explicit_close0
implicit_close0
disconnect_close0
in_middle_of_command_close0
explicit_free_result0
implicit_free_result0
explicit_stmt_close0
implicit_stmt_close0
mem_emalloc_count0
mem_emalloc_amount0
mem_ecalloc_count0
mem_ecalloc_amount0
mem_erealloc_count0
mem_erealloc_amount0
mem_efree_count0
mem_efree_amount0
mem_malloc_count0
mem_malloc_amount0
mem_calloc_count0
mem_calloc_amount0
mem_realloc_count0
mem_realloc_amount0
mem_free_count0
mem_free_amount0
mem_estrndup_count0
mem_strndup_count0
mem_estndup_count0
mem_strdup_count0
proto_text_fetched_null0
proto_text_fetched_bit0
proto_text_fetched_tinyint0
proto_text_fetched_short0
proto_text_fetched_int240
proto_text_fetched_int0
proto_text_fetched_bigint0
proto_text_fetched_decimal0
proto_text_fetched_float0
proto_text_fetched_double0
proto_text_fetched_date0
proto_text_fetched_year0
proto_text_fetched_time0
proto_text_fetched_datetime0
proto_text_fetched_timestamp0
proto_text_fetched_string0
proto_text_fetched_blob0
proto_text_fetched_enum0
proto_text_fetched_set0
proto_text_fetched_geometry0
proto_text_fetched_other0
proto_binary_fetched_null0
proto_binary_fetched_bit0
proto_binary_fetched_tinyint0
proto_binary_fetched_short0
proto_binary_fetched_int240
proto_binary_fetched_int0
proto_binary_fetched_bigint0
proto_binary_fetched_decimal0
proto_binary_fetched_float0
proto_binary_fetched_double0
proto_binary_fetched_date0
proto_binary_fetched_year0
proto_binary_fetched_time0
proto_binary_fetched_datetime0
proto_binary_fetched_timestamp0
proto_binary_fetched_string0
proto_binary_fetched_blob0
proto_binary_fetched_enum0
proto_binary_fetched_set0
proto_binary_fetched_geometry0
proto_binary_fetched_other0
init_command_executed_count0
init_command_failed_count0
com_quit0
com_init_db0
com_query0
com_field_list0
com_create_db0
com_drop_db0
com_refresh0
com_shutdown0
com_statistics0
com_process_info0
com_connect0
com_process_kill0
com_debug0
com_ping0
com_time0
com_delayed_insert0
com_change_user0
com_binlog_dump0
com_table_dump0
com_connect_out0
com_register_slave0
com_stmt_prepare0
com_stmt_execute0
com_stmt_send_long_data0
com_stmt_close0
com_stmt_reset0
com_stmt_set_option0
com_stmt_fetch0
com_deamon0
bytes_received_real_data_normal0
bytes_received_real_data_ps0
ODBC Supportenabled
Active Links0
ODBC libraryWin32
odbc.allow_persistentOnOn
odbc.check_persistentOnOn
odbc.default_cursortypeStatic cursorStatic cursor
odbc.default_dbno valueno value
odbc.default_pwno valueno value
odbc.default_userno valueno value
odbc.defaultbinmodereturn as isreturn as is
odbc.defaultlrlreturn up to 4096 bytesreturn up to 4096 bytes
odbc.max_linksUnlimitedUnlimited
odbc.max_persistentUnlimitedUnlimited
PCRE (Perl Compatible Regular Expressions) Supportenabled
PCRE Library Version8.37 2015-04-28
pcre.backtrack_limit10000001000000
pcre.recursion_limit100000100000
PDO supportenabled
PDO driversmysql
PDO Driver for MySQLenabled
Phar: PHP Archive supportenabled
Phar EXT version2.0.2
Phar API version1.1.1
SVN revision$Id: 72d7e004b07d106bb1ef7c5663a186cbae621385 $
Phar-based phar archivesenabled
Tar-based phar archivesenabled
ZIP-based phar archivesenabled
gzip compressionenabled
bzip2 compressiondisabled (install pecl/bz2)
OpenSSL supportdisabled (install ext/openssl)
Phar based on pear/PHP_Archive, original concept by Davey Shafik.
Phar fully realized by Gregory Beaver and Marcus Boerger.
Portions of tar implementation Copyright (c) 2003-2009 Tim Kientzle.
phar.cache_listno valueno value
phar.readonlyOnOn
phar.require_hashOnOn
Reflectionenabled
Version$Id: eff8bdc65b0beaf8f4ade6f06f848e6d43dfd826 $
Session Supportenabled
Registered save handlersfiles user
Registered serializer handlersphp_serialize php php_binary wddx
session.auto_startOffOff
session.cache_expire180180
session.cache_limiternocachenocache
session.cookie_domainno valueno value
session.cookie_httponlyOffOff
session.cookie_lifetime00
session.cookie_path//
session.cookie_secureOffOff
session.entropy_fileno valueno value
session.entropy_length00
session.gc_divisor10001000
session.gc_maxlifetime14401440
session.gc_probability11
session.hash_bits_per_character55
session.hash_function00
session.namePHPSESSIDPHPSESSID
session.referer_checkno valueno value
session.save_handlerfilesfiles
session.save_pathno valueno value
session.serialize_handlerphpphp
session.upload_progress.cleanupOnOn
session.upload_progress.enabledOnOn
session.upload_progress.freq1%1%
session.upload_progress.min_freq11
session.upload_progress.namePHP_SESSION_UPLOAD_PROGRESSPHP_SESSION_UPLOAD_PROGRESS
session.upload_progress.prefixupload_progress_upload_progress_
session.use_cookiesOnOn
session.use_only_cookiesOnOn
session.use_strict_modeOffOff
session.use_trans_sid00
Simplexml supportenabled
Revision$Id: 6b8e23a01a85046737ef7d31346da5164505c179 $
Schema supportenabled
Sockets Supportenabled
SPL supportenabled
InterfacesCountable, OuterIterator, RecursiveIterator, SeekableIterator, SplObserver, SplSubject
ClassesAppendIterator, ArrayIterator, ArrayObject, BadFunctionCallException, BadMethodCallException, CachingIterator, CallbackFilterIterator, DirectoryIterator, DomainException, EmptyIterator, FilesystemIterator, FilterIterator, GlobIterator, InfiniteIterator, InvalidArgumentException, IteratorIterator, LengthException, LimitIterator, LogicException, MultipleIterator, NoRewindIterator, OutOfBoundsException, OutOfRangeException, OverflowException, ParentIterator, RangeException, RecursiveArrayIterator, RecursiveCachingIterator, RecursiveCallbackFilterIterator, RecursiveDirectoryIterator, RecursiveFilterIterator, RecursiveIteratorIterator, RecursiveRegexIterator, RecursiveTreeIterator, RegexIterator, RuntimeException, SplDoublyLinkedList, SplFileInfo, SplFileObject, SplFixedArray, SplHeap, SplMinHeap, SplMaxHeap, SplObjectStorage, SplPriorityQueue, SplQueue, SplStack, SplTempFileObject, UnderflowException, UnexpectedValueException
Dynamic Library Supportenabled
Internal Sendmail Support for Windowsenabled
assert.active11
assert.bail00
assert.callbackno valueno value
assert.quiet_eval00
assert.warning11
auto_detect_line_endings00
default_socket_timeout6060
url_rewriter.tagsa=href,area=href,frame=src,input=src,form=fakeentrya=href,area=href,frame=src,input=src,form=fakeentry
user_agentno valueno value
Tokenizer Supportenabled
WDDX Supportenabled
WDDX Session Serializerenabled
XML Supportactive
XML Namespace Supportactive
libxml2 Version2.9.2
XMLReaderenabled
core library versionxmlrpc-epi v. 0.51
php extension version0.51
authorDan Libby
homepagehttp://xmlrpc-epi.sourceforge.net
open sourced byEpinions.com
XMLWriterenabled
Opcode CachingUp and Running
OptimizationEnabled
StartupOK
Shared memory modelwin32
Cache hits0
Cache misses1
Used memory10935728
Free memory1062806096
Wasted memory0
Interned Strings Used memory352048
Interned Strings Free memory8036560
Cached scripts1
Cached keys1
Max keys7963
OOM restarts0
Hash keys restarts0
Manual restarts0
opcache.blacklist_filenameno valueno value
opcache.consistency_checks00
opcache.dups_fixOffOff
opcache.enableOnOn
opcache.enable_cliOnOn
opcache.enable_file_overrideOffOff
opcache.error_logno valueno value
opcache.fast_shutdown11
opcache.file_update_protection22
opcache.force_restart_timeout180180
opcache.inherited_hackOnOn
opcache.interned_strings_buffer88
opcache.load_comments11
opcache.log_verbosity_level11
opcache.max_accelerated_files40964096
opcache.max_file_size00
opcache.max_wasted_percentage55
opcache.memory_consumption10241024
opcache.mmap_baseno valueno value
opcache.optimization_level11
opcache.preferred_memory_modelno valueno value
opcache.protect_memory00
opcache.restrict_apino valueno value
opcache.revalidate_freq6060
opcache.revalidate_pathOffOff
opcache.save_comments11
opcache.use_cwdOnOn
opcache.validate_timestampsOnOn
Zipenabled
Extension Version$Id: d4f77eb4ed7171a6ed0c11bcc4ebefc16af10e21 $
Zip version1.12.5
Libzip version0.11.2
ZLib Supportenabled
Stream Wrappercompress.zlib://
Stream Filterzlib.inflate, zlib.deflate
Compiled Version1.2.7.3
Linked Version1.2.7.3
zlib.output_compressionOffOff
zlib.output_compression_level-1-1
zlib.output_handlerno valueno value
Additional Modules
Module Name
Environment
VariableValue
_FCGI_X_PIPE_\\.\pipe\IISFCGI-62ddaa8e-aea9-4f7d-b3c5-0e159908e4d5
PHP_FCGI_MAX_REQUESTS1000
ALLUSERSPROFILEC:\ProgramData
APPDATAC:\Windows\system32\config\systemprofile\AppData\Roaming
APP_POOL_CONFIGC:\inetpub\temp\apppools\DefaultAppPool\DefaultAppPool.config
APP_POOL_IDDefaultAppPool
CommonProgramFilesC:\Program Files\Common Files
CommonProgramFiles(x86)C:\Program Files (x86)\Common Files
CommonProgramW6432C:\Program Files\Common Files
COMPUTERNAME10_243_140_222
ComSpecC:\Windows\system32\cmd.exe
FP_NO_HOST_CHECKNO
LOCALAPPDATAC:\Windows\system32\config\systemprofile\AppData\Local
NUMBER_OF_PROCESSORS2
OSWindows_NT
PathC:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Program Files (x86)\MySQL\MySQL Utilities 1.3.5\;C:\Program Files\QCloud\Monitor\Barad;
PATHEXT.COM;.EXE;.BAT;.CMD;.VBS;.VBE;.JS;.JSE;.WSF;.WSH;.MSC
PROCESSOR_ARCHITECTUREAMD64
PROCESSOR_IDENTIFIERIntel64 Family 6 Model 79 Stepping 1, GenuineIntel
PROCESSOR_LEVEL6
PROCESSOR_REVISION4f01
ProgramDataC:\ProgramData
PSModulePathC:\Windows\system32\WindowsPowerShell\v1.0\Modules\
PUBLICC:\Users\Public
SystemDriveC:
SystemRootC:\Windows
TEMPC:\Windows\TEMP
TMPC:\Windows\TEMP
USERDOMAINWORKGROUP
USERNAME10_243_140_222$
USERPROFILEC:\Windows\system32\config\systemprofile
windirC:\Windows
PHP Variables
VariableValue
_SERVER["_FCGI_X_PIPE_"]\\.\pipe\IISFCGI-62ddaa8e-aea9-4f7d-b3c5-0e159908e4d5
_SERVER["PHP_FCGI_MAX_REQUESTS"]1000
_SERVER["ALLUSERSPROFILE"]C:\ProgramData
_SERVER["APPDATA"]C:\Windows\system32\config\systemprofile\AppData\Roaming
_SERVER["APP_POOL_CONFIG"]C:\inetpub\temp\apppools\DefaultAppPool\DefaultAppPool.config
_SERVER["APP_POOL_ID"]DefaultAppPool
_SERVER["CommonProgramFiles"]C:\Program Files\Common Files
_SERVER["CommonProgramFiles(x86)"]C:\Program Files (x86)\Common Files
_SERVER["CommonProgramW6432"]C:\Program Files\Common Files
_SERVER["COMPUTERNAME"]10_243_140_222
_SERVER["ComSpec"]C:\Windows\system32\cmd.exe
_SERVER["FP_NO_HOST_CHECK"]NO
_SERVER["LOCALAPPDATA"]C:\Windows\system32\config\systemprofile\AppData\Local
_SERVER["NUMBER_OF_PROCESSORS"]2
_SERVER["OS"]Windows_NT
_SERVER["Path"]C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Program Files (x86)\MySQL\MySQL Utilities 1.3.5\;C:\Program Files\QCloud\Monitor\Barad;
_SERVER["PATHEXT"].COM;.EXE;.BAT;.CMD;.VBS;.VBE;.JS;.JSE;.WSF;.WSH;.MSC
_SERVER["PROCESSOR_ARCHITECTURE"]AMD64
_SERVER["PROCESSOR_IDENTIFIER"]Intel64 Family 6 Model 79 Stepping 1, GenuineIntel
_SERVER["PROCESSOR_LEVEL"]6
_SERVER["PROCESSOR_REVISION"]4f01
_SERVER["ProgramData"]C:\ProgramData
_SERVER["ProgramFiles"]C:\Program Files
_SERVER["ProgramFiles(x86)"]C:\Program Files (x86)
_SERVER["ProgramW6432"]C:\Program Files
_SERVER["PSModulePath"]C:\Windows\system32\WindowsPowerShell\v1.0\Modules\
_SERVER["PUBLIC"]C:\Users\Public
_SERVER["SystemDrive"]C:
_SERVER["SystemRoot"]C:\Windows
_SERVER["TEMP"]C:\Windows\TEMP
_SERVER["TMP"]C:\Windows\TEMP
_SERVER["USERDOMAIN"]WORKGROUP
_SERVER["USERNAME"]10_243_140_222$
_SERVER["USERPROFILE"]C:\Windows\system32\config\systemprofile
_SERVER["windir"]C:\Windows
_SERVER["ORIG_PATH_INFO"]/index.php
_SERVER["URL"]/index.php
_SERVER["SERVER_SOFTWARE"]Microsoft-IIS/8.5
_SERVER["SERVER_PROTOCOL"]HTTP/1.1
_SERVER["SERVER_PORT_SECURE"]0
_SERVER["SERVER_PORT"]80
_SERVER["SERVER_NAME"]acgc.com.cn
_SERVER["SCRIPT_NAME"]/index.php
_SERVER["SCRIPT_FILENAME"]E:\web\index.php
_SERVER["REQUEST_URI"]/
_SERVER["REQUEST_METHOD"]GET
_SERVER["REMOTE_USER"]no value
_SERVER["REMOTE_PORT"]48549
_SERVER["REMOTE_HOST"]60.211.111.20
_SERVER["REMOTE_ADDR"]60.211.111.20
_SERVER["QUERY_STRING"]no value
_SERVER["PATH_TRANSLATED"]E:\web\index.php
_SERVER["LOGON_USER"]no value
_SERVER["LOCAL_ADDR"]10.144.64.121
_SERVER["INSTANCE_META_PATH"]/LM/W3SVC/1
_SERVER["INSTANCE_NAME"]DEFAULT WEB SITE
_SERVER["INSTANCE_ID"]1
_SERVER["HTTPS_SERVER_SUBJECT"]no value
_SERVER["HTTPS_SERVER_ISSUER"]no value
_SERVER["HTTPS_SECRETKEYSIZE"]no value
_SERVER["HTTPS_KEYSIZE"]no value
_SERVER["HTTPS"]off
_SERVER["GATEWAY_INTERFACE"]CGI/1.1
_SERVER["DOCUMENT_ROOT"]E:\web
_SERVER["CONTENT_TYPE"]no value
_SERVER["CONTENT_LENGTH"]0
_SERVER["CERT_SUBJECT"]no value
_SERVER["CERT_SERIALNUMBER"]no value
_SERVER["CERT_ISSUER"]no value
_SERVER["CERT_FLAGS"]no value
_SERVER["CERT_COOKIE"]no value
_SERVER["AUTH_USER"]no value
_SERVER["AUTH_PASSWORD"]no value
_SERVER["AUTH_TYPE"]no value
_SERVER["APPL_PHYSICAL_PATH"]E:\web\
_SERVER["APPL_MD_PATH"]/LM/W3SVC/1/ROOT
_SERVER["WEBSOCKET_VERSION"]13
_SERVER["HTTP_X_ORIGINAL_URL"]/
_SERVER["HTTP_X_REWRITE_URL"]/
_SERVER["HTTP_USER_AGENT"]Mozilla/5.0 (Macintosh; Intel Mac OS X 10_13_6) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/79.0.3945.88 Safari/537.36
_SERVER["HTTP_HOST"]acgc.com.cn
_SERVER["HTTP_ACCEPT_LANGUAGE"]zh-CN,zh;q=0.9,en;q=0.8,en-GB;q=0.7
_SERVER["HTTP_ACCEPT_ENCODING"]gzip
_SERVER["HTTP_ACCEPT"]text/html,application/xhtml+xml,application/xml;q=0.9,image/webp,image/apng,*/*;q=0.8,application/signed-exchange;v=b3;q=0.9
_SERVER["HTTP_CONTENT_LENGTH"]0
_SERVER["HTTP_CONNECTION"]keep-alive
_SERVER["FCGI_ROLE"]RESPONDER
_SERVER["PHP_SELF"]/index.php
_SERVER["REQUEST_TIME_FLOAT"]1612288267.3689
_SERVER["REQUEST_TIME"]1612288267
PHP Credits
PHP Group
Thies C. Arntzen, Stig Bakken, Shane Caraveo, Andi Gutmans, Rasmus Lerdorf, Sam Ruby, Sascha Schumann, Zeev Suraski, Jim Winstead, Andrei Zmievski
Language Design & Concept
Andi Gutmans, Rasmus Lerdorf, Zeev Suraski, Marcus Boerger
PHP Authors
ContributionAuthors
Zend Scripting Language EngineAndi Gutmans, Zeev Suraski, Stanislav Malyshev, Marcus Boerger, Dmitry Stogov, Xinchen Hui, Nikita Popov
Extension Module APIAndi Gutmans, Zeev Suraski, Andrei Zmievski
UNIX Build and ModularizationStig Bakken, Sascha Schumann, Jani Taskinen
Windows PortShane Caraveo, Zeev Suraski, Wez Furlong, Pierre-Alain Joye, Anatol Belski
Server API (SAPI) Abstraction LayerAndi Gutmans, Shane Caraveo, Zeev Suraski
Streams Abstraction LayerWez Furlong, Sara Golemon
PHP Data Objects LayerWez Furlong, Marcus Boerger, Sterling Hughes, George Schlossnagle, Ilia Alshanetsky
Output HandlerZeev Suraski, Thies C. Arntzen, Marcus Boerger, Michael Wallner
SAPI Modules
ContributionAuthors
AOLserverSascha Schumann
Apache 1.3 (apache_hooks)Rasmus Lerdorf, Zeev Suraski, Stig Bakken, David Sklar, George Schlossnagle, Lukas Schroeder
Apache 1.3Rasmus Lerdorf, Zeev Suraski, Stig Bakken, David Sklar
Apache 2.0 FilterSascha Schumann, Aaron Bannert
Apache 2.0 HandlerIan Holsman, Justin Erenkrantz (based on Apache 2.0 Filter code)
Caudium / RoxenDavid Hedbor
CGI / FastCGIRasmus Lerdorf, Stig Bakken, Shane Caraveo, Dmitry Stogov
CLIEdin Kadribasic, Marcus Boerger, Johannes Schlueter, Moriyoshi Koizumi, Xinchen Hui
ContinuityAlex Leigh (based on nsapi code)
EmbedEdin Kadribasic
FastCGI Process ManagerAndrei Nigmatulin, dreamcat4, Antony Dovgal, Jerome Loyet
ISAPIAndi Gutmans, Zeev Suraski
litespeedGeorge Wang
NSAPIJayakumar Muthukumarasamy, Uwe Schindler
phpdbgFelipe Pena, Joe Watkins, Bob Weinand
phttpdThies C. Arntzen
pi3webHolger Zimmermann
Sendmail MilterHarald Radi
thttpdSascha Schumann
tuxSascha Schumann
WebJamesAlex Waugh
Module Authors
ModuleAuthors
BC MathAndi Gutmans
Bzip2Sterling Hughes
CalendarShane Caraveo, Colin Viebrock, Hartmut Holzgraefe, Wez Furlong
COM and .NetWez Furlong
ctypeHartmut Holzgraefe
cURLSterling Hughes
Date/Time SupportDerick Rethans
DB-LIB (MS SQL, Sybase)Wez Furlong, Frank M. Kromann
DBASascha Schumann, Marcus Boerger
DOMChristian Stocker, Rob Richards, Marcus Boerger
enchantPierre-Alain Joye, Ilia Alshanetsky
eregRasmus Lerdorf, Jim Winstead, Jaakko Hyvätti
EXIFRasmus Lerdorf, Marcus Boerger
fileinfoIlia Alshanetsky, Pierre Alain Joye, Scott MacVicar, Derick Rethans
Firebird driver for PDOArd Biesheuvel
FTPStefan Esser, Andrew Skalski
GD imagingRasmus Lerdorf, Stig Bakken, Jim Winstead, Jouni Ahto, Ilia Alshanetsky, Pierre-Alain Joye, Marcus Boerger
GetTextAlex Plotnick
GNU GMP supportStanislav Malyshev
IconvRui Hirokawa, Stig Bakken, Moriyoshi Koizumi
IMAPRex Logan, Mark Musone, Brian Wang, Kaj-Michael Lang, Antoni Pamies Olive, Rasmus Lerdorf, Andrew Skalski, Chuck Hagenbuch, Daniel R Kalowsky
Input FilterRasmus Lerdorf, Derick Rethans, Pierre-Alain Joye, Ilia Alshanetsky
InterBaseJouni Ahto, Andrew Avdeev, Ard Biesheuvel
InternationalizationEd Batutis, Vladimir Iordanov, Dmitry Lakhtyuk, Stanislav Malyshev, Vadim Savchuk, Kirti Velankar
JSONOmar Kilani, Scott MacVicar
LDAPAmitay Isaacs, Eric Warnke, Rasmus Lerdorf, Gerrit Thomson, Stig Venaas
LIBXMLChristian Stocker, Rob Richards, Marcus Boerger, Wez Furlong, Shane Caraveo
mcryptSascha Schumann, Derick Rethans
MS SQLFrank M. Kromann
Multibyte String FunctionsTsukada Takuya, Rui Hirokawa
MySQL driver for PDOGeorge Schlossnagle, Wez Furlong, Ilia Alshanetsky, Johannes Schlueter
MySQLZeev Suraski, Zak Greant, Georg Richter, Andrey Hristov
MySQLiZak Greant, Georg Richter, Andrey Hristov, Ulf Wendel
MySQLndAndrey Hristov, Ulf Wendel, Georg Richter, Johannes Schlüter
OCI8Stig Bakken, Thies C. Arntzen, Andy Sautins, David Benson, Maxim Maletsky, Harald Radi, Antony Dovgal, Andi Gutmans, Wez Furlong, Christopher Jones, Oracle Corporation
ODBC driver for PDOWez Furlong
ODBCStig Bakken, Andreas Karajannis, Frank M. Kromann, Daniel R. Kalowsky
OpenSSLStig Venaas, Wez Furlong, Sascha Kettler, Scott MacVicar
Oracle (OCI) driver for PDOWez Furlong
pcntlJason Greene, Arnaud Le Blanc
Perl Compatible RegexpsAndrei Zmievski
PHP ArchiveGregory Beaver, Marcus Boerger
PHP Data ObjectsWez Furlong, Marcus Boerger, Sterling Hughes, George Schlossnagle, Ilia Alshanetsky
PHP hashSara Golemon, Rasmus Lerdorf, Stefan Esser, Michael Wallner, Scott MacVicar
PosixKristian Koehntopp
PostgreSQL driver for PDOEdin Kadribasic, Ilia Alshanetsky
PostgreSQLJouni Ahto, Zeev Suraski, Yasuo Ohgaki, Chris Kings-Lynne
PspellVlad Krupin
ReadlineThies C. Arntzen
RecodeKristian Koehntopp
ReflectionMarcus Boerger, Timm Friebe, George Schlossnagle, Andrei Zmievski, Johannes Schlueter
SessionsSascha Schumann, Andrei Zmievski
Shared Memory OperationsSlava Poliakov, Ilia Alshanetsky
SimpleXMLSterling Hughes, Marcus Boerger, Rob Richards
SNMPRasmus Lerdorf, Harrie Hazewinkel, Mike Jackson, Steven Lawrance, Johann Hanne, Boris Lytochkin
SOAPBrad Lafountain, Shane Caraveo, Dmitry Stogov
SocketsChris Vandomelen, Sterling Hughes, Daniel Beulshausen, Jason Greene
SPLMarcus Boerger, Etienne Kneuss
SQLite 3.x driver for PDOWez Furlong
SQLite3Scott MacVicar, Ilia Alshanetsky, Brad Dewar
Sybase-CTZeev Suraski, Tom May, Timm Friebe
System V Message based IPCWez Furlong
System V SemaphoresTom May
System V Shared MemoryChristian Cartus
tidyJohn Coggeshall, Ilia Alshanetsky
tokenizerAndrei Zmievski, Johannes Schlueter
WDDXAndrei Zmievski
XMLStig Bakken, Thies C. Arntzen, Sterling Hughes
XMLReaderRob Richards
xmlrpcDan Libby
XMLWriterRob Richards, Pierre-Alain Joye
XSLChristian Stocker, Rob Richards
ZipPierre-Alain Joye, Remi Collet
ZlibRasmus Lerdorf, Stefan Roehrich, Zeev Suraski, Jade Nicoletti, Michael Wallner
PHP Documentation
AuthorsMehdi Achour, Friedhelm Betz, Antony Dovgal, Nuno Lopes, Hannes Magnusson, Georg Richter, Damien Seguy, Jakub Vrana, Adam Harvey, Peter Cowburn
EditorPhilip Olson
User Note MaintainersDaniel P. Brown, Thiago Henrique Pojda
Other ContributorsPreviously active authors, editors and other contributors are listed in the manual.
PHP Quality Assurance Team
Ilia Alshanetsky, Joerg Behrens, Antony Dovgal, Stefan Esser, Moriyoshi Koizumi, Magnus Maatta, Sebastian Nohn, Derick Rethans, Melvyn Sopacua, Jani Taskinen, Pierre-Alain Joye, Dmitry Stogov, Felipe Pena, David Soria Parra, Stanislav Malyshev, Julien Pauli, Stephen Zarkos, Anatol Belski, Remi Collet, Ferenc Kovacs
Websites and Infrastructure team
PHP Websites TeamRasmus Lerdorf, Hannes Magnusson, Philip Olson, Lukas Kahwe Smith, Pierre-Alain Joye, Kalle Sommer Nielsen, Peter Cowburn, Adam Harvey, Ferenc Kovacs, Levi Morrison
Event MaintainersDamien Seguy, Daniel P. Brown
Network InfrastructureDaniel P. Brown
Windows InfrastructureAlex Schoenmaker
PHP License
This program is free software; you can redistribute it and/or modify it under the terms of the PHP License as published by the PHP Group and included in the distribution in the file: LICENSE
This program is distributed in the hope that it will be useful, but WITHOUT ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
If you did not receive a copy of the PHP license, or have any questions about PHP licensing, please contact license@php.net.
上一篇: 自动寻路脚本
下一篇: 夜光带你走进 传奇语言php(29)
