装备等级限制脚本
114 阅读
module RPG
class Weapon
def level
return 1 if @description.split(/LV/)[1] == nil
return @description.split(/LV/)[1]
end
def str
return 1 if @description.split(/STR/)[1] == nil
return @description.split(/STR/)[1]
end
def dex
return 1 if @description.split(/DEX/)[1] == nil
return @description.split(/DEX/)[1]
end
def agi
return 1 if @description.split(/AGI/)[1] == nil
return @description.split(/AGI/)[1]
end
def int
return 1 if @description.split(/INT/)[1] == nil
return @description.split(/INT/)[1]
end
# def description
# return @description.split(/LV/)[0] + "{装备等级" + level + "}"
# end
end
class Armor
def level
end
def str
end
def dex
end
def agi
end
def int
end
# def description
# end
end
end
class Game_Actor < Game_Battler
# ● 可以装备判定
# item : 物品
def equipable?(item)
# 武器的情况
if item.is_a?(RPG::Weapon)
# 包含当前的职业可以装备武器的场合
if $data_classes[@class_id].weapon_set.include?(item.id) and item.level.to_i<=@level
if item.str.to_i<= str and item.dex.to_i<= dex and item.agi.to_i<= agi and item.int.to_i<= int
return true
end
end
end
# 防具的情况
if item.is_a?(RPG::Armor)
# 不包含当前的职业可以装备武器的场合
if $data_classes[@class_id].armor_set.include?(item.id) and item.level.to_i<=@level
return true
end
end
end
return false
end
end
# ■ Window_EquipItem
# 装备画面、显示浏览变更装备的候补物品的窗口。
class Window_EquipItem < Window_Selectable
# ● 刷新
def refresh
if self.contents != nil
self.contents.dispose
self.contents = nil
end
@data = []
# 添加可以装备的武器
if @equip_type == 0
weapon_set = $data_classes[@actor.class_id].weapon_set
for i in 1...$data_weapons.size
if $game_party.weapon_number(i) > 0 and weapon_set.include?(i) and @actor.equipable?($data_weapons[i])
@data.push($data_weapons[i])
end
end
end
# 添加可以装备的防具
if @equip_type != 0
armor_set = $data_classes[@actor.class_id].armor_set
for i in 1...$data_armors.size
if $game_party.armor_number(i) > 0 and armor_set.include?(i) and @actor.equipable?($data_armors[i])
if $data_armors[i].kind == @equip_type-1
@data.push($data_armors[i])
end
end
end
end
# 添加空白
@data.push(nil)
# 生成位图、描绘全部项目
@item_max = @data.size
self.contents = Bitmap.new(width - 32, row_max * 32)
for i in 0...@item_max-1
draw_item(i)
end
end
end
上一篇: 传奇M2提示脚本错误 125.77.31.*福州高防服务器搭建
下一篇: 在一个脚本内部调用另一个脚本注意事项
