按键精灵开发传奇手游教程-现在比较火的美杜莎传奇为例
80 阅读
 多线程检测周围有无玩家或者怪物 Dim h Sub test_thread(var1, var2) Dim shuijitime = 0 Dim configtime = ReadUIConfig("无怪随机时长") configtime = configtime * 1000 TracePrint configtime While True Dim intX,intY //在战斗状态 FindMultiColor 355,1129,420,1208,"1A7581","14|-6|1F6773,-6|3|DAFFF8,-2|0|C5FAEE,4|33|0E3F48,-9|33|1E6670,-3|-4|B4FFF3,5|11|81BCC0,-21|30|65C3CD,9|29|42A6B1",0,0.9,intX,intY If intX > -1 And intY > -1 Then If ReadUIConfig("攻击敌人") Then Swipe 120, 1189, 193, 1260 End If FindMultiColor 420,3,473,47,"BEF3FE","0|6|75B5D3,-12|17|386481,-13|8|72B6D0,0|1|9DD5E7,-10|11|599CBD,-3|10|63A5C7,0|1|9DD5E7",0,0.9,intX,intY If intX > -1 And intY > -1 Then ShowMessage "发现敌人", 4000, 350, 350 If ReadUIConfig("见人就飞") Then 使用随机 End If If ReadUIConfig("见人就砍") Then Tap 122, 1192 Delay 500 End If End If //无怪随机 FindMultiColor 410,1,481,53,"7CBCD3","-9|10|4086A5,-15|-2|67A9BC,-1|5|5EA5C2,-11|11|3B809D,-1|1|65ACC8,-5|-8|AFE3ED",0,0.9,intX,intY If intX = -1 And intY = -1 Then shuijitime = shuijitime + 1000 If shuijitime = configtime Then ShowMessage "无怪随机", 4000, 350, 350 使用随机 shuijitime = 0 End If Else shuijitime = 0 End If TracePrint shuijitime TracePrint configtime End If TracePrint "线程中" Delay 1000 Wend End Sub h=Thread.Start(test_thread,"执行检测任务","开始线程") //查找背包回城石,并拖动到快捷栏 方便使用 Function 查找回城石() Rem 重新查找回城石 Dim intX,intY FindPic 139,578,217,951,"Attachment:回城石.png","000000",0,0.8,intX,intY If intX > -1 And intY > -1 Then 查找回城石 = 1 Tap intX,intY Exit Function End If //查询背包回城石 While True Delay 1000 Tap 461,1238 Delay 2000 FindPic 0,0,720,1028,"Attachment:关闭背包.png","000000",0,0.8,intX,intY If intX > -1 And intY > -1 Then Exit While End If Wend //拖动回城石 FindPic 243,105,671,703,"Attachment:回城石.png","000000",0,0.8,intX,intY If intX > -1 And intY > -1 Then TouchDown intX, intY, 1 TouchMove 181,907, 1, 700 TouchUp 1 End If Delay 1500 FindPic 145,873,208,944,"Attachment:回城石.png","000000",0,0.8,intX,intY If intX > -1 And intY > -1 Then Tap intX, intY Exit Function Else 购买回城 Goto 重新查找回城石 End If 查找回城石 = 0 End Function
控制界面编辑教程
按下图 一定要先布局 再设置标签页 再拖其他按钮 这样界面才比较简洁好看!!!
最后:如有不懂可以@我。需要代码也可以直接开源
上一篇: 传奇996_7——地图刷怪
下一篇: 使用python实现自动化脚本(自动键鼠器)
